Hypalon Rubber Rollers in Pickling Line Are Failing
Q. We are rubber roller manufacturer supplying to steel pickling line. Our hypalon rollers fail sometimes on the surface. What could be the cause?
Onkar Bhandarirubber roller manufacturer - Rohini, DELHI
August 19, 2017
A. Hi Onkar. Although you've given us nothing at all to go on, hopefully someone with experience running a pickling line will offer a couple of common causes. But give us more detail about what you mean by "fail sometimes on the surface". Thanks.
August 2017
