Heat Treat Al Casting for 300 hrs Salt Spray Life
Q. I am currently working on Aluminum casting(material LM6) part which needs min. 300-hour salt spray life, so kindly suggest the Heat treatment for the same.
Awaiting for quick responses.
PRAJWAL GAWALI
- Pune, Maharashtra, India
April 17, 2017
A. Hi Prajwal. There are some "quasi heat treat" procedures for steel, like Nitriding, which can improve the corrosion resistance, but I am not personally aware of using heat treatment to improve the corrosion resistance of aluminum. Must the casting remain bare rather than being anodized, plated or powder coated?
April 2017
