Restoring black exterior door hardware
Q. Loved your answers but my hardware did not pass the water test!!
So what now? It is a French door lever and dead bolt semi rough finish, black color, very faded.
(Emtek)
Vicki Payne
Home Owner - Kerens Texas
August 2, 2024
Brass Darkening Solution
brass_darkening_solution
A. Hi Vicki,
If you want it black but don't want it painted, your only realistic choice is probably brass darkening solution ⇨
followed by a clearcoat or wax this on eBay or Amazon [affil links] .
Try your best to clean it well with Spic n Span this on eBay or Amazon [affil links] or other strong detergent while wearing dishwashing gloves this on eBay or Amazon [affil links] first because the blackening solution won't work as well on fingerprints or oils as on clean metal.
Q. I've just cleaned the chipped gloss paint off the Victorian cast iron doorknob on my front door. It looked great for a couple of days but now there are spots of rust. I really don't want to cover it in paint again. What would the Victorians have done?
Marian Hall
- Birmingham, UK
A. As a stopgap to keep the doorknob from rusting any more I'd go ahead and wax it, if it is cast iron it will take a bit to work it into the metal (sweat it out later on in an oven if you can think of a better sealant). I'm going to check with Bill to see if he has any other suggestions.
Marc Banks
- Elizabeth City, North Carolina
Beeswax
beeswax
A. Well after a bit of a chat, it turns out I was right, most Victorians would have waxed the doorknob while it was still warm. Probably using beeswax ⇨
(you can use commercial paste wax in a pinch). Just wire brush off the rust (or 00 steel wool this on eBay or Amazon [affil links] ) and let the piece warm in the sun. Then apply the wax.
Marc Banks
Q. I have exterior door hardware that is black and approximately 5 years old. The finish is faded due to the sun. Any suggestions on how to bring it back to life and to its original rich black color?
Karen S [last name deleted for privacy by Editor]
- Johns Creek Georgia USA
May 9, 2016
A. Hi Karen. There are a lot of things that are black, and a lot of things that are called door hardware, so it's hard to guess what the finish is. If you are talking about hinges and heavy items like that, my guess is they are painted, and should be repainted. If you're talking about the doorhandle/lockset it is probably some sort of plating and/or physical vapor deposition that you are not going to be able to duplicate yourself, although it might be simply brass darkening solution this on eBay or Amazon [affil links]
I would suggest trying a thin single-component clearcoat like Everbrite [a finishing.com supporting advertiser], or if the item is small enough you can try car wax this on eBay or Amazon [affil links] . The idea being that sometimes such metal acquires fading due to a microscopic roughness that starts developing with wear; and simply getting a smooth finish on it again can restore the look. Everbrite suggests a really simple test: just wet the area with water -- if it looks good when wet, then a clearcoat may restore it; if being wet doesn't help, don't bother :-)
thumbs up signThanks for your reply, Ted. Sorry I didn't specify what the hardware is. It's a door handle and lock set. I just tried the "wet test" and sure enough, it improved the look! So I'm off to purchase Everbrite and bring life back to my front door hardware!
Thanks so very much for your help! I really do appreciate it!
Karen S [returning]
