Measure & Control Stress in Acid Tin Plating
Q. Hi All
I would like to know if there is any standard for, stress levels allowed in a Tin bath
I do the checking by bend strip method. and my bath is acid bath stannate if that information may help.
it will be great if some body could give me a lead at least.
Sreehari TK
Process Engineer - United Arab Emirates
March 21, 2016
A. Hello Sreehari, there are standards for compressive stress in tin plating, but you would have to have the equipment to measure for it. For Mil Spec applications a plated "foil" is normally submitted to a reputable lab that has the equipment to check for it. As you know, whisker growth is the sign of undesirable stress in the deposit. The whiskers can appear right away or in weeks, months or years in storage. If you are using a organic additive keep tight control of the addition rate. Your Tin supplier may offer compressive stress testing. The bend test is probably the most common way of monitoring. You could also perform your own storage test with samples dated. Good luck!
Mark Baker
Process Engineering - Phoenix, Az USA
March 21, 2016
