Is it okay to Cadmium plate over chrome plate?
Q. I have a landing gear cylinder part that has been chrome plated in the port bores, and a little bit of the inner diameter. Can I Cad plate all of the external area of the landing cylinder? Would it create any bonding issues over chrome?
Ron B [last name deleted for privacy by Editor]- Tampa, Florida, USA
February 17, 2016
A. Firstly your chrome plated areas should be masked before you attempt to cad. plate the part as this will probably require grit blasting of the surface before cad. Aerospace - Dublin, Ireland. February 18, 2016 A. Hi Ron, Aerospace - Yeovil, Somerset, UK February 18, 2016 |
February 2016
For the second time this week we have strongly contrasting opinions on a subject -- that's the way it goes sometimes. Much of my plating process knowledge is just book knowledge rather than hands-on, so when one source says it perhaps can't or shouldn't be done, and the other source says they've done it, I personally have to go with the person who has done it :-)
