Nickel chrome plating low thickness issue
Q. In many parts which we were using nickel chrome plating due to aesthetic quality appearance, we face frequent issues with less plating thickness. What will be the causes to overcome the issues completely, which is repeated and affects my production.
C kesavaram
engineer - Chennai, tamilnadu, INDIA
November 6, 2015
A. Hi,
KESHAVRAM
The nickel chrome plated part with low thickness causes corrosion failure, appearance-wise no good because of low coverage of nickel. Follow the customer's required spec.
popat patel
Popatbhai B. Patel
January 12, 2016
