High-Speed Rotor Coating Material Needed
Hello,
Could anyone tell me what kind of material is suitable for high-speed rotor coating (which is used in semi-conductor, vacuum environment) ? What properties should a high-speed rotor own
(such as corrosion resistance, wear resistance, hardness, smoothness,uniformity, adhesion, dyability, etc.) ? IF there is any help available, it will be gratefully appreciated.
- Hsin Chu, Taiwan, R.O.C
We have good experience with Teflon* coatings onto the rotors. You can test it.
Jordi PujolCOATRESA SL - Barcelona, Spain
Hello,
Please be informed that I am chemical eng. and I am working on the powder coating for plastics ( as ABS & PP ). I need to information about production of P.C. for plastic and I want the information about producers of equipment for user of this powder coating . IF there is any help available, it will be greatly appreciated.
Thanks and best regards,
Roudsar Sanat Eng. Co. - Tehran, IRAN
