Thread 60/56
Galvannealed vs. Hot Dip Galvanized
Q. Dear Sirs; I am the owner of a small midwest supplier of industrial cleaning compounds and iron phosphates. One of my top accounts is going to start producing their products (currently cold rolled steel) using galvannealed steel. My question is what is the best way to prep this metal prior to painting? The products mentioned are rather large and bulky, and would not fit on a conveyor or monorail system.
Sincerely,
industrial supply
publicly reply to Robert B
Q. Hello ,
Can anyone tell me the difference between a hot dip galvanize steel from a galvannealed steel? Thanks.
Most likely, which is cheaper? Can they both be powder coated?
- Billerica, Massachusetts
publicly reply to Sharon S
A. Hot dipped galvanized steel is produced by immersing steel into a bath of molten zinc, resulting in the formation of a pure zinc coating on the steel surface. "Galvanneal" refers to steel with a zinc-iron alloy coating. This is produced by heating a hot dipped galvanized surface so that the zinc coating and the top layer of the steel surface essentially meld together to form a zinc-iron alloy. Galvanneal would most likely be more expensive because of the additional processing. Either surface can be powder coated but you should consult the powder coating manufacturer to determine what type of pretreatment is required.
Patrick Patton- Westlake, Ohio
publicly reply to Patrick Patton
A. 1. Both processes involve coating the object with molten Zinc in a batch or continuous process. The main difference is that with the Galvannealed steel, the object is then post-processed by heating in an oven to induce diffusion alloying, creating the characteristic Zinc-Iron (6-15%) coating. See
ASTM A653,
ASTM A924, and
ASTM A902.
2. Expect the Galvannealed steel price to reflect the cost of the extra processing (heat treatment).
3. Both can be effectively powder coated. Check with the steel and powder coating vendors and reference ASTM D2092 for the most effective surface preparation techniques.
- Merrifield, Virginia
publicly reply to Ted Bellinger
A. Sharon,
I'm a metallurgical engineer working in a galvanizing plant and I have to admit that Patrick and Ted answered your question very well. Just to add a few details of my own, a galvanneal steel has better paintability and weldability than galvanized steel. However it is less resistant to corrosion since the coating is lighter and not as adhesive to steel (because of the diffusion of iron in the zinc coating).
galvanizing company - Windsor, Ontario, Canada
publicly reply to Luc LeBlanc
Q. Dear Sir,
Kindly clarify as to what percentage extent is paintability and weldability increased with galvannealed process compared to galvanised sheet, and point out the technical differences of galvannealed to this time electro-galvanised metal sheet.
Thank you for your assistance
Warm regards,
- Mauritius
publicly reply to JOOMRATEE Yasseen
A. Hello, Joomratee. Galvanneal is designed to be painted; galvanizing and zinc plating are designed to be left unpainted (although it is possible to successfully paint them). So galvanneal is more paintable, and I think that's the whole answer. "By what percentage?" would force you to tell us precisely what spec and what method you would use to measure adhesion and under exactly what circumstances (aging time, corners vs. flats, how you intend to assign percentages, and what formula you want used to correlate all this data into a single index.
There is a TV commercial for an anti-aging cosmetic for women which claims it "Reduces the appearance of fine lines by 78 percent"
They're ludicrously trying to quantify a qualitative parameter. What they probably did was to start by choosing the answer they wanted (50% isn't inspiring enough, 90% wouldn't be believable enough; maybe 75%? Close, but too "round". Then they design a "test" to deliver that number. "I can't see any difference from back here ... I'll move up a bit ... still not seeing it ... change the bulb from 60 Watts to 100 watts ... oops, too close, I'll move back 6 inches ... okay I'm counting ... the coarse lines look the same but I'm seeing 78% fewer fine lines now." "Perfect! Cut. That's a wrap!"
The zinc thickness of electrogalvanized (zinc electroplated) sheet is far more controllable than the thickness of hot dip galvanized, but it is usual for the thickness to be far less -- perhaps 1/4 the thickness of hot dipping, probably less. Patient application of the search engine will reveal dozens of threads about that subject on this site. Good luck!
publicly reply to Ted Mooney
Q. I want to know what kind of steel sheets can be galvannealed. Is there any constraint in galvannealing all kinds of steel sheets. If so why?
Fanish Tiwari- Chennai, India
November 13, 2009
publicly reply to Fanish Tiwari
Hi, Fanish. Do you mean thick vs. thin sheets, old vs. new sheets, pickled & oiled vs. cold finished, high carbon vs. low carbon, large sheets vs. small ones, flat vs. formed, sharp edged vs. rounded edge? Sorry, I don't know the answer to your question, but this forum usually offers more enthusiasm towards questions which describe an actual situation rather than cast in the abstract. Sometimes a potential responder doesn't feel like replying if it will take several pages to cover every possible if, and, & but. Thanks! ![]() Ted Mooney, P.E. Striving to live Aloha finishing.com - Pine Beach, New Jersey November 13, 2009 publicly reply to Ted Mooney |
A. To answer your question I need to ask a few.
Typically galvanizing is done in a line with coil which can then be sheeted. There are certainly other galvanizing processes with an actual dipping that could be done to coat sheets of steel.
I have yet to hear of anyone willing to put a galvanneal product on a sheet; this would involve laying the sheets down to run them thru an annealing cycle. Typically the annealing is done within seconds of the galv coating being applied. What type of application are you looking at?
- fishers, Indiana, USA
September 22, 2010
publicly reply to Marc Masters
Q. Hi I own 3 processing houses (Slitting & Cut To Length) in India.
My Question is:
Why manufacture Galvannealed steel whereas a zero spangle or skinpass Hot Dip Galvanize steel can give almost similar type of powder coating finish?
product developer - Maharashtra, Mumbai
March 21, 2011
publicly reply to Mehul Doshi
A. Hi Mehul. I don't have a definitive answer for you, but I think galvanneal, due to the additional annealing, probably has more iron on the surface for more reliable adhesion.
A. The difference between galvanizing and galvannealing is nothing except what we do do force iron to diffuse to zinc coating. This function is post annealing after zinc coating normally to 500 °C in a furnace about 30 meters long. In this treatment the iron will distribute to zinc coating and the brittle phase will become more homogenized; this will cause galvanized sheet to have more weld-ability especially for automotive applications.
Each way that it can diffuse iron to zinc coating will use like reducing Al in zinc bath and Si in steel substrate.
msc - esfahan,Iran
October 5, 2014
publicly reply to Jamal ashouri
Where to get metal in gunstock or dark slate, and how to form it?
Q. I HAVE GOT A REQUEST FOR CABINETS WRAPPED WITH METAL IN A GUNSTOCK COLOR OR DARK GRAY SLATE COLOR. WHERE CAN I GET THE MATERIAL AND HOW CAN I FORM IT?
DARRYL TERRYrenaissance - decatur, Alabama
March 14, 2014
publicly reply to DARRYL TERRY
A. Hi Darryl. Please remember that people can have very different finishes in mind when they use words like "gunstock color" or "dark gray slate", so there is a fair probability that what you furnish may not be what the customer had in mind. But you could buy galvanized sheet (available in large quantity from a steel warehouse or small quantity from a hardware store). You could form it with a sheetmetal brake, and then you could try a patina for zinc. Good luck.
March 2014
Q. I want to know: Can we transform a galvanizing line to galvanneal line?
R D singhsteel - Delhi,Ghaziabad
August 9, 2015
publicly reply to R D singh
Q. A new Customer has asked us to Powder Coat Paint our Galvanized product Black. Your answers are convincing me to trial the product in galvanneal. How much will the Galvanneal material spike our Waste Water for Zinc concentrations?
Tim TaborFarm & Ranch - Liberty, Kentucky USA
March 30, 2019
publicly reply to Tim Tabor
A. Hi Tim. You are implying something but I don't know what :-(
Are you saying that you only currently offer this product in galvanized, and don't yet do powder coating, but you want to, and you want to build a pretreatment line for preparing the material for powder coating?
It may be possible to powder coat without any pretreatment to 'spike your waste water'. But remember that galvanneal is brittle; you don't powder coat it until all forming and bending is done.
April 2019
