Twin Moulded Non Conducting Plastic Also Getting Plated.
We have received a twin material ABS - polycarbonate logo to be Satin nickel plated only on the grey ABS portion.
Our problem is that the blue polycarbonate, supposedly nonconducting material is also getting partially / fully covered with plating.
What are we doing wrong; is it the chromic acid etch, or the silver nitrate based activation or the electroless copper.
How can we avoid coating the blue polycarbonate ?
Khozem Vahaanwala
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
saify logo
"Electroless Plating"
by Mallory & Hajdu
en_mallory1990
AbeBooks
"Electroless Copper and Nickel-phosphorous Plating"
by Sha, Wu, & Keong
ec-en_sha2011
AbeBooks
Hi, KV.
I think the only real difference between ABS and polycarbonate from a plating perspective is that ABS etches better for better adhesion of the plating; there is nothing inherent in the polycarbonate that prevents it from becoming activated and getting plated. I haven't worked on a similar job, so I could be completely wrong, but I don't think you'll solve this problem through chemistry adjustments, but only by masking at some point.
But I am not familiar with silver nitrate being a part of an ABS plating cycle. As far as I know, you use palladium seed chemistry for electroless copper or nickel, not silver nitrate.
