Surface Chemistry after Chromate Conversion
What is the galvanic effect of contact between a nickel-plated surface an aluminum surface with Alodine chromate conversion? What is the surface chemistry of an aluminum part after chromate conversion?
Brett B [surname deleted for privacy by Editor]microwave systems - San Jose, California
A conversion coating will improve the corrosion protection between nickel and aluminum, but from what I could find in a quick look is that you will need to know
the alloy of the aluminum
the base metal of the nickel plated fastener
the environment of the couple
how important the integrity of the fastening is to life and limb. --Tom
