Annealing Zinc Die Cast
July 6, 2015
Q. I have a zinc die cast object that has a rolled edge that holds a plate in place. It is a closed cylinder with the bottom sealed by a flat plate held in place by a rolled edge.
I'd like to lift the rolled edge up from the plate to remove the plate but want to do it non destructively.
I understand that zinc becomes more ductile over a very specific temperature range.
I'm hoping to be able to re-roll the edge back after lifting it.
My thoughts so far are to try and lift the rolled edge in a sort of spinning process, i.e., turning the object in a lathe chuck whilst lifting the edge with a pry. Any better suggestions to accomplish this would be appreciated, even if they are only SWAGs! :)
Thanks guys/gals,
Doug
(SWAGs are "Scientific Wild-a**ed guesses) :)
Douglas Gourlay
Hobbyist - Hamilton, Ontario CANADA
