Masking for Decorative Chrome Plating
November 29, 2014
I have two motorcycle wheels that I'm sending out for decorative chrome plating. It is extremely hard to remove the plating build up in the bearing receiver bores without removing aluminum. The plating company does an excellent job of polishing and plating but they will not mask the bores. They recommended Stop Off Lacquer MICCROSTOP. I have a problem with paying $83.00 for a gallon of MICCROSTOP so I'm looking for another absolute solution.
Now it is your turn.
Ronald Becker
- Wichita, Kansas
December 8, 2014
A. Plug the bores tight with a piece of plastic, rubber or plastic wrapped wood.
Guillermo (Bill) Marrufo
- Monterrey, NL, Mexico
