Thread 596/89
Most Economical Substrate for Skin Contact
August 18, 2014
Q. I am currently designing a skin electrode system and am trying to determine the best substrate metal for silver or gold plating. Are there any quick "rules of thumb" when choosing a combination? I want to avoid specifying a substrate metal that would be difficult to plate with either precious metal (such as copper or stainless steel). Would a low to mid carbon steel (such as 5160 or 1018) be easy for a plate house to work with? I would like to avoid nickel entirely in the design.
Adam
Product Designer - Baltimore, Maryland, USA
publicly reply to Adam Brooks
A. Yes Adam, low to mid carbon cold finished steel is relatively easy to plate. You'll probably want to do a silver strike followed by silver plating, or a gold strike followed by gold plating. Depending on the brightness and economy you seek, you might want a layer of white bronze (nickel substitute) before the gold.
August 2014
publicly reply to Ted Mooney
