How to remove aluminium adhered to stainless steel die
June 30, 2014
Q.
Hello All.
We are facing a typical issue. We do aluminium pressure dies casting and at times the aluminium thin layer gets deposited on the pins and other curved surfaces of the stainless steel die.
We tried dry ice blasting but the result was not that good. Can anyone suggest how to get rid of metal to metal adherents like the one mentioned above?
Will preheating and then dry ice blasting help?
Thanks a ton.
Sudhir
- India
A. Dissolve it away with sodium hydroxide solution?
Dave Wichern
July 3, 2014
July 2014
Sounds right to me, Dave.
