Chrome Layer Only is Peeling from Nickel-Chrome Plated Brass
March 18, 2014
Q. I make faucet and plumbing fixtures.
Plating procedure : Brass material - Bright Nickel - Chrome (Automatic Equipment)
One of our electroplating parts has a problem.
Chrome plating layer only has peeled.
There was no peeling with bright nickel.
I've experienced a peeling of bright nickel before, but chrome layer peeling have never occurred before. How can it have occurred?
- South Korea
A. If the nickel becomes passivated, then poor chromium coverage or peeling way occur. The cause of nickel passivation may be too long a time between nickel and chromium plating.
Or, the problem may be that the pre-dip before chromium plating is too weak.
- Cleveland, Ohio USA
March 24, 2014
Thanks for your kind answer.
I agree with your answer. But I couldn't reproduce same kind of trouble, so I couldn't answer to my customer.
So I did some trick. After Ni plating, I dipped parts in Ni solution tank with no current for three hours. And I re-electroplated Ni on it, then Cr plating.
I could get same trouble on the part. Wow!! It was obviously caused by Ni layer passivation. But I think passivated Ni layer could be activated by Cr pre-dippings. So I hidden passivated Ni layer between Ni layer and succeeded.
Thank you, again!!
- Incheon City, South Korea
Hi Steve. Very interesting trouble shooting, thank you. Although it looked like a chrome plating problem, apparently it was actually a nickel plating problem.
March 24, 2014
I'm glad that you solved your problem.
LK
March 25, 2014
