Need To Clean Aluminum 6061-T6 with Acid etch Process for Ultra High Vacuum Chamber Application
October 24, 2013
Q. I would like to clean the Aluminum (6061-T6) through the acid etch process. The parts will be used in Vacuum chamber which will be getting 10^-6 torr to 10^-9 torr vacuum. I would like to get full process chart with the chemical composition and temperature and time for the acid etch/cleaning process. The final surface finish would be Satin Matte finish. Also please mention any standard process/ standard anywhere available to buy and I will buy it.
This product will be using in high vacuum. To reduce the outguessing we need to chemically clean the aluminum.
- Rockaway, New Jersey, USA
A. Hi Herry,
Rather than trying to self-formulate I would suggest you talk to one or all of the major suppliers of cleaning products such as Henkel, Chemetall, Atotech, Macdermid...
A quick search in the internet will reveal a number of suppliers in your area, alternatively check through the supporting advertisers on this site.
