How to verify that anodizing is completely stripped?
July 24, 2013
Q. Hellow,
I am trying to remove the anodized layer of aluminum part, and apply chemical conversion coating again.
And I must verify & prove that the anodic layer is completely removed.
But, the part is already in assembled condition.
So, I am going to remove the anodizing by manual sanding.
Therefore, we are looking for a portable inspection method.
Is there anybody who can help me?
- Busan, South Korea
A. Hi.
I normally check with a multi meter. Since an anodized coating is non conductive, a well stripped anodized piece would show conductivity.
- Penang, Malaysia
July 30, 2013
Q. Thank you. SK Cheah.
Multi-meter can check on point to point locations.
But, I need to verify the entire stripped surface as requested by my customer.
Is there any detection solution for the above purpose ?
Thanks in advance !
