Proper anode to cathode ratio for plating? What are the consequences if too low?
July 10, 2013
Q. We are electroplating Pd/Ni 60/40 alloy. What are the consequences of a small anode to cathode area (ex. <1:1)? Thanks!
Tess Molina
- Hawthorne, California, USA
A. Hi Tess,
Optimum anode-to-cathode ratio for Pd/Ni alloy plating is 1:1 to 3:1. Too low anode area may result rough plating, pitting and/or poor thickness distribution,
David
David Shiu
David Shiu
July 17, 2013
A. Hello Tess,
You will experience lower deposition rates, less than desirable thickness distribution, and also plate more metal from solution than you want. If too low, anode polarization is also possible.
Mark Baker
- Mesa, Arizona, USA
July 29, 2013
thumbs up signThanks so much for all the responses!
Tess Molina
