Zamak 5 parts do not pass humidity tests
July 10, 2013
Q. Hello, I have a problem. Zamak 5 parts do not pass humidity tests. The coating is clear chromate coating. I'd like to replace it with Cu-Ni-Cr. Could you advise?
- Auburn Hills, Michigan, USA
A. Hi Zbiegniew. Yes, properly copper-nickel-chrome plated Zamak will pass any humidity test. However, it will be much more expensive.
Thank you for the excellent graphic, but I'm not quite sure what I'm looking at. The black item is perhaps powder coated? The baseplate with the phillips or torx screws is apparently a chromated zamak item, but are the castellated nut and stud zamak or are they zinc plated steel? An unaware mechanic would snap a zamak stud in a heartbeat.
Because of galvanic corrosion concerns it is necessary to understand what material all of the items are made of because they are all electrically connected. I think I would lean towards zinc alloy plating everything except the powder coated component. Good luck.
July 11, 2013
A. That idea might work but only if it is done properly. Done improperly, the part might look good after plating but will fail the testing miserably. Bright acid copper, duplex nickel and tight control of the Cr deposit should be maintained. If you have a small pit or two caused by careless plating or incorrect process the coating will probably fail quickly. ![]() Blake Kneedler Feather Hollow Eng. - Stockton, California July 12, 2013 Before you switch to Cu-Ni-Cr, try plating some pure zinc over that junk alloy to cover up the metals on the surface that do not "take" the chromate, THEN, apply a good zinc chromate over the pure zinc. ![]() Robert H Probert Robert H Probert Technical Services ![]() Garner, North Carolina ![]() July 12, 2013 |
