Welds and Oil Rubbed Bronze
June 25, 2013
Q. I work for a metal fabrication outfit in Phoenix, Arizona. We are working on a project using 385 Bronze and several pieces must be welded together. My question is, Is there a way to weld so that the weld is less noticeable when the Oil Rubbed Finish is applied? Perhaps there is a weld rod or technique we are not currently aware of. With our Aluminum builds we have switched to weld rod that can be anodized.
Chris R
- Phoenix, Arizona, USA
