Incralac Supplier in Germany or the Netherlands
May 13, 2013
Q. I am a goldsmith who also makes brass sculptures.
I am busy putting the finishing touches on a complicated brass sculpture called the Palindrome Cannon.
brass sculpture
I need help in finding a supplier of Incralac this on eBay or Amazon [affil links] in either Germany of the Netherlands.
I have found one in the UK, but the transport costs are about 6 times more that the product costs.
Any help would be greatly appreciated.
Hans Meevis
Brass Sculpture - Dusseldorf, Germany.
A. Hi Hans. Does it really need to be purchased by brand name rather than by the performance of the brass lacquer? G.J. Nikolas [a finishing.com supporting advertiser] has good products and a good distribution system.
May 14, 2013
June 11, 2013
A. Dear Hans!
Try Kremer Pigmente GmbH - 1 liter Incralac this on eBay or Amazon [affil links] = 48 E! Or Deffner & Johann GmbH. You can make your own clearcoat too: dissolve 75 gms Paraloid B 44 resin in 1 lit toluene, pretreat your object with 3 % benzotriazole this on eBay or Amazon [affil links] solution/dissolved in ethanol!
Hope it helps and good luck!
- Zagreb, Croatia
June 19, 2013
thumbs up signThank you Goran.
I contacted the suppliers you suggested and Viola! I have the Incralac this on eBay or Amazon [affil links] .
Very, very much appreciated.
Also to Ted, I contacted the supplier you mentioned but I received no response. Maybe the query got lost?
Anyway, thank you to both of you.
Cheers, Hans
Hans Meevis
