Coating to prevent high temperature discoloration of stainless steel
February 25, 2013
Q. As a part of a development project for a manufacturer of valves, we are searching for a high temperature protective coating, which can prevent oxidation.
As a part of the manufacture of the valve, it is heated to approximately 1000 °C, in order to anneal the valve. After the heating the stainless steel is quenched in water. The manufacturer wants to avoid miss-coloring of the valves. The manufacturer have tried protective gas with success, however the expenses of the gas was unacceptable high, and there for they are searching for a cheaper alternative.
Can you recommend us a "protective coating"?
RFQ: Can the product be delivered in Europe, or does the manufacturer have a European representative we can contact?
Best Regards
Anette, Denmark
Anette Rasmussen
Consultant - Lyngby, Denmark
A. What if you tried ceramic or enamel painting? Good luck.
Cair Shishani
Khair Shishani
March 3, 2013
March 5, 2013
A. Anette
Copper plating is used to mask select surfaces from absorbing carbon during carburizing operations. Might work in a vacuum environment also. You would need to strip the copper after your annealing operation. There might be some outgassing from/of the copper plating.
Willie Alexander
- Colorado Springs, Colorado
March 9, 2013
A. Dear Anette
You experience discoloring due to oxidizing of stainless steel, a situation well known from welding or annealing.
I see 3 possibilities
1. Remove oxygen by the use of protective gases or vacuum
2. Protective coating, which have to be applied and removed
3. Remove discoloring
Since I have no clue of sizes, it is difficult to put up prices, but solution 2 sounds as the most expensive to me.
I guess you need an economic alternative for your costumer, and remove discolor on stainless can be done by pickling. You did not mention the stainless type, so I can not come up with a pickling solution, but some salt of HF is always convenient.
Best regards
Bo Konig
- Aalborg Denmark
