Thread 591/70
Thermal Spray Aluminium Coating
February 25, 2013
Q. I would like to know the following details for the Aluminum thermal spray coating on carbon steel substrate for Marine application:
1. Aluminum thermal spray coating - Procedure with substrate preparation method.
2. Finish (seal coat) material with detail composition and supplier name.
Mohamed Ali
- India
publicly reply to Mohamed Ali
February 26, 2013
A. That would take several books to cover all of the possibilities.
Basically, you have given no useful information. Even with a great deal of information, the answer is to long for a simple answer at a site like this.
I think that you need to find a good consultant that can sit down with you and find out enough information to be able to design a complete system for you.
The cost can be considerable. You might want to contract the work out for a while.
publicly reply to James Watts
