Problem in Electroless Nickel Coating on Al6061
I use the following EN bath for Ni-B plating on Al6061:
NiCl2.6H2O, Glycin, DMAB (Dimethyl amino borane), Pb(CH3COOH),T=71 oC,pH=6.7 (adjusted by NH4OH).
The Deposition rate is 4um/hr. By increasing the concentration of Ni ions in solution, The deposition rate increases, but the morphology of the surface does change and becomes fragile. I would appreciate if somebody could give me any idea. What is the best accelerator which I can add ionto the bath to increase the deposition rate?
N.Dadvand
- Halifax, Canada
1. Why do you use Electroless based on B? For most applications a low phosphor EN will do and it is much easier to operate.
2. I can see that you use a home made EN solution. A well balanced EN solution contains more ingredients than you use in your formulation. For a higher plating rate you will probably need a proprietary EN solution.
sara michaeli
sara michaeli signature
Sara Michaeli
Tel-Aviv-Yafo, Israel
