Carbon Black in black inks attacking aluminum
Q. Is there any evidence to support carbon black in inks can attack aluminum. The application is ink applied to hot stamping foil.
Brian Hill- Lexington, North Carolina, USA
October 3, 2012
A. Carbon Black per se, NO, but what is the pH of the solution. Any pH ± 1 away from 7.0 will attack aluminum, particularly with heat.
First of three simultaneous responses -- October 4, 2012
A. I do not know about carbon, but I do know that a common pencil marking on Al in a coastal area will slowly eat through it.
James Watts- Navarre, Florida
Second of three simultaneous responses -- October 4, 2012
A. I would check the MSDS of the particular ink you are using. If there are certain solvents in your ink, that could be a cause of corrosion.
Aluminum in itself, is very susceptible to corrosion, hence the need for coatings.
Without seeing a picture of your situation, I'm also wondering if the "corrosion" you are noting is the ink actually preventing that natural oxidation of aluminum that will occur around the inked areas.
Marc Green
anodizer - Boise, Idaho
Third of three simultaneous responses -- October 5, 2012
