Holey utility zinc sink!
Q. I have an OLD zinc utility sink with a corroded hole. The bottom of the sink is also rusted. Can repairs be made? I would rather not replace it with a polypropylene tub but keep it for the history. The building is 100 years old - the sink must be close to that!
zinc utility sink with corroded hole 1 zinc utility sink with corroded hole 2
Thank you!
Sharon Pomponio
property manager - Washington, DC USA
October 2, 2012
Cold Galvanizing Spray
Rust Converter Spray
A. Hi Sharon.
Epoxy is underrated; I used JB Weld this on eBay or Amazon [affil links] on a burst outdoor faucet and it lasted for years. If it's a pinhole, I'd fill it with the epoxy. If it's larger, I'd cut a small piece of galvanized sheet metal and use epoxy to glue it over the hole.
After that, apply rust converter this on eBay or Amazon [affil links] and then zinc rich paint (sometimes called cold galvanizing paint to the inside. Good luck.
October 2, 2012
