Electroformed nickel foil peels off mandrel too easily
Q. We have been plating Nickel direct on SS304, for the last many years. But I could not understand something: after coating about 8 to 10 times the adhesion reduces to nil. Please let me know why? Does the property of the SS304 change in the electrolyte after 8 to 10 times of working (we plate, and then peel to form a foil). Any other better substitute, please advise.
Ravinder Singh- Gurgaon, India
September 5, 2012
A. I am surprised it takes 8-10 goes to get no adhesion! Stainless steel usually has a passive layer of chromium oxides on it, so any direct deposition of metal will have poor adhesion. I assume you do no pretreatment of the stainless steel, so I expect the oxide layer to increase in thickness and the degree of steel passivation to increase. Hence, you are broadly correct in thinking that the stainless steel surface does change with multiple use. If you want good adhesion, you need to prepare it and use nickel strike.
A. Perhaps it is not the stainless steel mandrel but a contaminated or un-balanced nickel solution instead.
G. Marrufo
Monterrey, NL, Mexico
September 18, 2012
