Polish on Chilled Cast Iron rolls
Q. Sir,
I am involved in re-grinding of chilled cast iron rolls. The sizes are 500, 600 MM OD and 1300 to 1800 mm length. Kindly suggest the way to improve the shine of polish after grinding. Is there any kind of polish sort of thing available? Kindly suggest.
John Abraham
John Abraham
- India
August 19, 2012
A. There isn't enough info to give you a good answer. Need weight of parts and volume. Possible solution might be to run parts in a barrel system with steel media.
tony kenton
AF Kenton
August 21, 2012
