Is black iron or galvanized pipe better for fire exit handrails?
Q. Which type of pipe is more practical to use for fire exit handrails, black iron pipe or galvanized iron pipe?
Kevin Roxas
- Philippines
June 13, 2012
A. Hi Kevin.
Black iron (plain steel) pipe will have no inherent corrosion resistance, whereas galvanized pipe will. On the other hand, it will be difficult to field paint galvanized pipe, and relatively easy to paint black pipe. So, if you intend to do a nice painting job, black will be better; if not, galvanized will be better.
June 15, 2012
