Corrosion resistance of copper, nickel and tin plating on CRCA
Q. We have terminal of CRCA material and in order to comply the salt spray of 240 hours , plating specified in sequence as Cu plating : 0.8 microns , Nickel plating : 8 microns and Tin plating : 12 micron.
Our plating supplier has doubt whether above plating specification will satisfy the salt spray testing of 240 hours.
Please provide your opinion on the above matter.
Customer - Pune, Maharastra, India
May 21, 2012
A. Yes it should pass, but the spec is really very outdated. Don't you have a Tin whisker problem with 12 microns as the final coat?
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
June 7, 2012
