Plating zinc onto steel "How To" and protection of the zinc afterwords
Q. I have a small steel ring that I would like to plate with zinc I was wondering what process I would go through to get the best finish on this ring to prevent rust and also to look nice , such as which acid should I use? I have 3 vinegar in bulk on eBay or Amazon [affil links] lemon juice and muriatic acid. I also have a small zinc anode that I got at a marine supply store. What steps should I take in prepping my ring and plating rig? Also how should I plate it? voltages,time,ect... also once its done plating how can I make the zinc look nice and shiny , and keep it that way because I know zinc tarnishes easy? perhaps Stay Brite, a brass sealer?
Garrett Tompkins
- Frisco, Texas, USA
May 17, 2012
May 18, 2012
A. If you're talking about a finger ring or anything else subject to wear and handling, zinc is a poor choice. Any topcoat will wear away and the since will discolor and soon wear away.
Tell us what the purpose of the ring is and we can make suggestions.
