How to do Tin Plating on Copper Lugs?
Q. Hi Friends , I have newly started my own electroplating plant. I deal in acid tin plating of copper lux^lugs metals. I have the necessary equipment but the problem now is I am confused as to when I have to polish/shine the copper lux^lugs metal? Is it before or after the plating procedure? Also, suggest which medias to be used -- SS media or Ceramic media.
Advise me ASAP. Any valuable replies is greatly helpful to me.
Parin Sheth
- Umbergaon, Gujarat, India
March 26, 2012
April 6, 2012
A. Hi Parin.
Sorry, I don't know quite what you mean by "Copper Lux". Is that a brand name / trade name? I do see pot and pans, and also sinks, sold under that name. What kind of components are you tin plating and why?
Although most polishing is done before plating, it seems to me that the media you are describing are associated with blasting or vibratory processing rather than polishing and buffing. Please try to explain what you are doing for me. Thanks!
May 16, 2012
Q. Dear Ted Mooney,
Thanks for the reply.
As I am a bit amateur on tin plating process, my earlier post was a bit confusing. Now I know the whole process but am left with some more doubts. Hope you can help me out.
The polishing part that I was talking about was in a vibratory machine. And the MEDIAS are associated with it.
The material that's gonna go into tin plating is COPPER LUGS (earlier was confused to COPPER LUX! my bad :))
Could you suggest me some LIQUIDS/SHAMPOOS that are poured into the vibratory machine.
Also, suggest which ones are better SS MEDIAS 202 or 304?
Awaiting for your reply.
Thanks Mate...
Parin Sheth
- India
May 22, 2012
Sorry, Parin, but I don't have much experience selecting media for mass finishing. We'll have to await reinforcements unless you'd like to consult the Metal Finishing Guidebook which has an excellent mass finishing chapter which discusses selecting same. Good luck.
Q. Dear sir,
We are into tin electroplating onto lugs. We don't have an issue while plating on loose lugs, but our client is asking for plating on chain type lugs. Now my question to you is how we can do it, and where can we get machine or equipment or any site which can help us.
mansoor
Mansoor Ali
- Thane, India
April 3, 2013
A. Hi Mansoor. Your website says that you already operate strip plating lines, and reel-to-reel plating lines. Therefore I'm not quite understanding what you mean by "chain type lugs" if they are neither discrete parts nor reel-to-reel parts. Is there a photo or sketch of the form in which you envision plating these objects to clarify what you are looking for; or can you explain what makes them different from reel-to-reel components? Thanks.
April 3, 2013
