How to define thickness of teflon coating on heat coil?
March 12, 2012
Q. Hi Mr,
I'm going to coat a heat coil surface, but I don't know how to define the layer thickness of Teflon; please recommend.
The heat coil will be used to heat NaOH 1.25% Reagent directly in a glass tank.
Thank you!
David Lv
- Suzhou, Jiangsu, China
Hi, David.
Teflon is a Dupont trade name. The only time I've seen similar materials applied to items like this it was via powder coating in a fluidized bed. It did not seem to me that there was any way to control it once the fluidized bed tank was made up. I think the powder manufacturer can answer the question. I'm not 100 percent sure that this is quite the coating you are looking for even.
March 13, 2012
I never had any luck using teflon to mask off racks, so doubt seriously if it will work on heaters.
The heaters that I have used that were "teflon" were teflon tubing over a round rod heater.
Teflon will not last with a regular heat density heater. It needs to be a derated heater (1/2). If you want longer life, you need to use double derated heaters(1/4)
Teflon has a coefficient of expansion about 10 times that of steel, so when it heats up, it swells.
Teflon heaters do not last forever and are a bit expensive.
I did use a teflon covered braided insulation over a single wire element. Double derated. It did not like places where it overlapped. It was a nice unit. I bought several as prototypes. They are nice for tiny plating tanks.
