Sealing polished aluminum against oxidation
March 10, 2012
Q. How do you seal polished aluminum?
What are the actual chemical names to do same?
Thanks in advance
ANGIE
hobbyist - Detroit, Michigan
Hi, Angie.
The aluminum can either be anodized or clear coated. Only fairly pure aluminum alloys can be clear anodized though -- do you know what alloy you are working with? Clearcoats range from simple one-part formulations that apply very thin coatings, to two-pack formulations like automotive clear coats.
March 11, 2012
