  Thread 580/95
How will Sulfamic Acid affect Stainless Steel, Ductile Iron and Carbon Graphite?
Q. We have been asked to design a rotary union that will have Sulfamic Acid pass through it for 1 day. Our customer is attempting to clean the inside of a large roll. The current material of our rotary union are Stainless steel and ductile iron. The seals are made of Carbon Graphite or silicon carbide. Based on this information do you think these materials would hold up for 1 day?
Bob Tuesley
- Three Rivers, Michigan, USA
December 12, 2011
publicly reply to Bob Tuesley
In short, run everything is compatible; however, there will probably be some galvanic current that may allow the sulfamic acid to dissolve some iron and nickel. Also, sulfamic acid in water solution has a pH so low that it begins breaking down into sulfuric acid and ammonia this on eBay or Amazon [affil links] - galvanic problem still there.
robert probert
probertbanner
December 14, 2011
publicly reply to Robert H Probert
