Outside diameter are undersized after plating.
December 2, 2011
Q. Please help us regarding this issues below.
Part name : Connector Conduit
Material : Cold Rolled Steel Per ASTM A108,Grade 12L14
Size : OD 0.9905~0.9912 x 0.945 x Threads Per ASME B1.20.1-1983
1.Machining Size.
OD 0.9905 ~ 0.9912
2.After Brazing Size.
OD 0.9890 ~ 0.9907
3.After Plating Size.
OD 0.9900 ~ 0.9924
Result after being follow the 3 process the Outside Diameter become small and undersized.
The sizes was OD 0.9884 ~ 0.9898
Will you help and guide us why this matter happens and which process has been effect the undersized condition.
Best regards,
- Malaysia
Hi, Hazani.
You did not mention what kind of plating you are applying, or its thickness -- but plating increases the outside diameter, it does not decrease it. So the problem is that the parts were undersized before plating.
December 5, 2011
