Teflon coating on Alumina Tubes to specified thickness
November 26, 2011
Can Teflon coating on Alumina Tubes be done with specified thickness?
The dielectric constant of the alumina can be either 9.6 or 9.9. Inner hole diameter of the Alumina tube is 3 mm excluding the Teflon film , outer diameter of the Alumina tube is 6 mm excluding the teflon film , the thickness of Teflon covered on both sides should be 0.5 mm.
Where can I find this? Thanks!
Ava Peng
filter design - Nanjing, China
