Hydrofluoric acid was accidentally added to Nickel Strike tank
Hi, this is the case: Addition of 1 gal of Hydrofluoric Acid instead of Hydrochloric Acid in the nickel Strike tank. With a capacity of 192 gal. How can this affect my bath. Thanks, I appreciate any suggestion.
Edecio V. [last name deleted for privacy by Editor]- Florida, USA
November 22, 2011
Hi, Edecio
Sorry, but the tank must be dumped because you will not be able to precipitate the fluoride out of it. It may be possible to plate out a significant portion of the nickel as scrap metal first though. It's an expensive mistake, but such a dangerous one that the lesson learned might be worth it :-(
November , 2011
Titanium basket corrosion. On deposit, the result is unknown (to me).
Daniel Hernandez- Bucaramanga, Santander, Colombia
November 22, 2011
