Painting support stand for pipes
October 30, 2011
Kindly let me know the configuration required for the painting spool stands eg: the support stand should be provided with the non compressible rope or 10mm Dia rod on the I BEAM to reduce the pipe contact area on the support. Kindly provide your valuable reply on this.
Syed Saleem
Painting Inspector
PAINTING INSPECTOR-OIL&GAS - DAMMAM
