Distinguishing between nickel deposited with Watts bath vs sulfamate bath
I have an electrodeposited nickel sample and want to know whether it was made using a sulfamate bath or a Watts bath. What tests should I order to determine this?
Helen Campanaro CampanaroJewelry Artisan - Bridgeport, Connecticut, USA
November 1, 2011
I can't think of an any foolproof way to tell them apart. why do you care?
I doubt that any shop that is primarily in the jewelry plating business would have a sulfamate bath as it is more expensive and rarely has the brightness of a Watts bath as the internal stress change would prohibit it for any low internal stress application.
James Watts- Navarre, Florida
November 8, 2011
November 9, 2011
Thanks, Jim, but I didn't follow the 2nd half of your answer, starting with "...as the internal stress change..."
Try metallography (it needs small sample of object).Electron microscopy(REM) can be useful too.Coatings from sulfamate baths must be much softer than that form Watts bath.Hope it helps and good luck!
November 10, 2011
November 10, 2011
Hi Ted,
The assumption was that it was a bright nickel since Watts nickel is frequently bright.
Any thing that you add to sulfamate to either make it hard or bright will destroy the bath for use as a low stress nickel product.
Therefore most platers that have a sulfamate nickel tank will not modify it and the plate tends to be matte.
Thanks Jim.
