Advantage and Disadvantage of heated Nickel Watt solution
Hi,
What is the advantage and disadvantage to the lead frame if Nickel watt solution heated up to 40-50 °C. Is the nickel deposition will increased? Appearance will become bright? etc.thickness will. Thank you.
Faizul Azli
Plating shop employee - Negeri Sembilan, Malaysia
October 13, 2011
Nickel plating efficiency and ductility are extremely low at temperatures below 40 °C. Higher temperatures are usually used, and 60 degrees C is not uncommon.
Lyle Kirman
First of two simultaneous responses -- ober 14, 2011
Second of two simultaneous responses -- October 14, 2011
Hi Faizul,
Advantages of higher nickel bath temp (up to ~50 °C):
1. Increase hardness.
2. Reduce pitting.
3. Less dullness, esp. at high current density area.
4. Less burning in high current density area.
Disadvantages of higher nickel bath temp (up to ~50 °C):
1. Reduce elongation/tensile strength of nickel deposit.
2. Brighter appearance (leadframe industry may not prefer a higher brightness).
David
David Shiu
David Shiu
