Nickel Strike needed OVER Ag plated over ceramic
I am in need of a nickel strike to be plated OVER Ag which has been plated over a ceramic base... any ideas?
Thank you...
Rick Hinkle
Plating Director - Phoenix, Arizona
September 27, 2011
September 28, 2011
This is one of the few cases that I would recommend a sulfamate strike rather than a Woods strike.
Reason, it uses a much higher pH and it plates a lot faster.
I would try it on scrap pieces starting with the highest recommended pH and lowering it as required.
