Residual electrical current in stainless steel strip
My friend is puzzled by his stainless device which after having DC power flowing through it (14 volts, 8 amps)for four seconds, retains a very slight current for two weeks. I cannot give away his purpose but the stainless is coiled closely to another strip of the same material.
Has the flow of electrons created a small, temporary, magnetic field? Whatever grade stainless it is, a magnet will not stick to it at all.
John Miller
Hobbyist - Lehigh Acres, Florida, USA
September 15, 2011
Hi, John.
Please look into the subject of "electrolytic capacitors" and see how closely your friend's device may resemble one. Good luck.
September 18, 2011
I am of the same opinion as Ted. The only solution is to ground it out as soon as the electricity quits flowing. Or reverse the current for a millisecond.
