Clear coat options for a steel commuter bike
A rookie question: My friend and I, both students of engineering design are starting a bike company targeted at bike-commuters in Chicago. All bikes are Chromoly steel. We want to build a bike with a raw clear finish that showcases the steel. It's been suggested that the best way to go about it is acid washing the frame, rinsing and then using a clear powder coat for the best finish. While this finish will look great on a bike, I want to give customers a bike that will withstand the winters in Chicago without flaking or rusting. No point having a great looking bike that has to be kept indoors all the time. Are there products or processes that can provide a great clear coat finish to steel and also protection from rust?
Sandeep GopalStudent/entrepreneur - Chicago, Illinois
September 14, 2011
Hi, Sandeep. I doubt it.
You could try grit blasting, followed by an electrophoretic prime coat, followed by either powder coating of a clear coat, or an automotive 2-pack clearcoat. But remember that there is a reason that auto manufacturers use galvanneal steel plus phosphatization before their e-coat primer, and it is that it affords them maximum corrosion resistance.
September 15, 2011
Thanks for replying. Appreciate your help.
Sandeep Gopal [returning]- Chicago, Illinois
September 21, 2011
