Chrome plating of linkage follower
Dear Sir,
I have a requirement of chrome plating to a be done in a linkage follower
used in steam turbine application. The plating to be done in inner counter shape of width 25.4 mm with grinding finish and the toleremnce to be maintained is 25.6±0.02.
I have attached the sketch for your reference.
kindly let me know the possibility.
designer (reverse engineering) - Bangalore, Karnataka, India
September 4, 2011
September 9, 2011
Probably to do, but possibly not affordable.
You left out critical information. How thick is the part. How much chrome will you put on it. How big a chamfer and can it be plated. What parent metal. How many parts at a time. Turn around time.
It will have to be ground after plate and if not done perfectly, the chrome will peel.
The part will require masking and will require custom bleeders (thieves).
