What is CED Painting?
What is CED painting Process. In which industries this process is used. What is Nickel plating. What is zinc coating. What is ABS painting. Pls explain all procedures.
Deepak Gupta Gupta
In Paint shop - Gurgaon, Haryana, India
August 30, 2011
August 31, 2011
Hi, Deepak,
CED stand for Cathodic Electrodeposition, the prevalent direction that E-coating (E-painting, Electropainting, Electrophoretic lacquering) processes operate in today. They are used both as primer finishes (automotive frames) and as final decorative finishes (electrphoretic lacquering). "ABS Painting" probably refers to painting OF ABS plastics rather than painting WITH ABS.
For the rest, you might contact www.nasf.org and inquire about their "Understanding Surface Finishing" brochure. Small quantities are either free or available at a very nominal charge.
