Mechanical finishing before electropolishing a 316SS tank
August 30, 2011
Hello,
I am designing a small open top mixing tank, 1000 liters working volume, SS316 to be used for washcoat slurry. I am thinking of electropolishing the inside to reduce product sticking to the tank wall but I need to know what is the best finish to do before electropolishing and what is the best recommended electropolishing to do.
Ghazi Toutounji
design engineer - Mississauga, Ontario, Canada
Hi, Ghazi.
For this particular application, where you're not concerned with waviness or with optical or aesthetic properties, I don't think mechanical pretreatment is required. The tank should be alkaline cleaned (preferably electrocleaned), thoroughly rinsed, and then electropolished. However, proper electropolishing requires a water-free solution plus careful control of current density to avoid etching, and is not as easy as falling off a log. I think you should send the tank out for electropolishing if you have no experience with it. Good luck.
August 31, 2011
Thank you for the feedback and sorry for the late response.
Ghazi Toutounji
October 4, 2011
