Hydrogen embrittlement when plating Aermet 100
I would like to know your opinion on plating ultra high strength high alloy steels like Aermet 100.
Most specs require to use test specimens of AISI 4340 for hydrogen embrittlement testing, which is a low alloy steel. When plating steels like Aermet, I doubt that the hydrogen embrittlement testing bars required per spec are representative. On the other hand one could say that the process is controlled per spec by the tests using AISI 4340. But when you're talking about production control testing, the non-representativeness would be a problem I guess.
I was asked for advise on putting a cad plating specification (AMSQQP416) on drawing by our design dept.
I work at an Aerospace company with design responsibility as you'd probably guessed.
Looking forward to your replies.
Best regards,
Jeroen Visser
Chief of Plating dept. - Helmond, The Netherlands
August 29, 2011
A. Jeroen,
Most of the hydrogen embrittlement test requirements have been developed for fasteners, such as ISO 15330, NASM 1312-5, etc. ASTM F519 is really the one exception, but as you already noted, it specifies the use of a 4340 steel specimen. However, section 1.3 states the following:
Components with ultimate strengths higher than 260 - 280 ksi may not be represented by the baseline. In such cases, the cognizant engineering authority shall determine the need for manufacturing specimens from the specific material and heat treat condition of the component. Deviations from the baseline shall be reported as required by section 12.1.2.
I would suggest that you follow the requirements of ASTM F519, but use specimens fabricated from production-representative material, i.e., Aermet 100. Here is an example of some testing done by the US Air Force that specifically used Aermet 100 specimens for ASTM F519 testing:
www.serdp.org/content/download/8646/105487/file/WP-1405-FR(2).pdf
Automotive module & component supplier - Michigan, USA
Hi Toby, - Helmond, The Netherlands A. I agree with Toby. I'll just add that ASTM F519 tensile testing specimens are widely used and are available in 4340 from various suppliers. That will not be the case with Aermet 100, so you will need to plan to machine your own specimens per the dimensions in ASTM F519. Jon Barrows, MSF, EHSSC Independence, Missouri |
