Choosing cadmium plating vs. hot dipped galvanized?
WHICH MATERIAL RESISTANCE IS BETTER, cadmium plated carbon steel of hot dipped galvanized carbon steel?
Neda Mousavi
marine - Tehran, Iran
August 27, 2011
Hi, Neda.
Cadmium is a bioaccumulative poison and must not be used except where its unique combination of properties makes it indispensable. It is never used anymore for a single property like corrosion resistance. For marine application use hot dip galvanized steel. Good luck.
August 29, 2011
November 2, 2011
Can I ask what it used for ? For different use , you should choose different material .
Best regards
Jenny
Jenny yang
trading co. - Wuxi City, Jiangsu province, China
