Is coefficient of friction of Zinc Nickel plating comparable to yellow zinc dichromate
We would like to know if Zinc Nickel plating has higher friction or comparable with yellow zinc dichromate, Zinc with olive drab
Harry Pongo
Product designer - Roseau, Minnesota, USA
August 26, 2011
Dichromate coatings are relatively soft and very thin. In friction situations they soon disappear leaving behind the underlying zinc. So, answering your Q, my guess is that zinc-nickel could last longer than plain zinc. G. Marrufo-Mexico
Guillermo Marrufo
Monterrey, NL, Mexico
August 31, 2011
September 3, 2011
Zinc Nickel Alloy plating can incorporate a friction additive to modify coefficient of friction on the finished fastener, it is one of the main reasons Zinc-Nickel Alloys are specified, together with higher corrosion resistance.
Hope this helps
Carlos
Carlos Cielak
- Mexico City, Mexico
You could always add a low friction sealer. Many places with threaded parts require a sealer that lowers the co-eff. of friction.
Jason Deible
Zinc/Chrome - Grand Rapids, Michigan
September 16, 2011
